Windows GUI with Typhoon H Pro
Syracuse, NY
Can anyone tell me if there is any other Din cable connector on the Typhoon H Pro? The only one I see is on the camera next to the SD card socket. I tried the Windows GUI software and it does not work at all with the Typhoon cable plugged in there.
Any suggestions or advice would be appreciated.
Thanks,
GeneW
I'm not sure about the TH Pro, but look behind the RH landing gear on the bottom side of the H. There should be another connection there. Let us know if it's there.
Thanks,
GeneW
Thank you. It was right where you said it was. I just never looked at the bottom of the H upside down. :)
GeneW
TroyBoy
