Wizard Aircraft Mode LED
I used the Wizard for the first time to fly the Typhoon-H today. It worked awesome.
When I had the drone in Smart Mode on the Wizard the manual states that the Wizard Aircraft Mode LED should be solid green.
It was blinking green but seemed to work fine?
I suspect the blinking green is the same as green/white on the H. Next time look at the status light on the H to see what it indicates after you are in the air.
essentailhoodie
