- Joined
- Jun 8, 2016
- Messages
- 874
- Reaction score
- 357
- Age
- 74
I can only find the instructions in German, Italian, Spanish and French. I can pretty much figure out what they say but would like the English version to print out.
Your Wizard came with a newer firmware than mine. If you look at the Wizard manual it says a quick press of the magic button switches mode. Thats the way mine worked when testing with UAV Pilot when I first received it. After I updated the firmware the magic button no longer worked to switch watch follow modes. Now I have to use the left right buttons.I have always used the left and right arrows to switch between Follow and Watch ?
Hi Kevinspage... where do yo download 3.3 firmware version for Wizard remote?I loaded firmware version 3.3 and the switch between watch and follow no longer responded to a quick press of the Magic Button in Smart mode like the Wizard manual says. Now you press the left and right arrow. Attached is an image of the Wizard button combinations from page 14 of the H manual.View attachment 19199
You can download the Updater and the manuals from the downloads repository on YuneecSkins.com. Firmware v3.0_2016 is there, but I am attaching v3.3 here. After downloading v3.3 remove the .txt from the end of the filename, it was added so it could be uploaded here. If you are running a version of Windows earlier than Windows 10 you may need the STM32 Virtual COM port driver mentioned in the updater instructions, here is an updated link to the download https://www.st.com/en/development-tools/stsw-stm32102.htmlHi Kevinspage... where do yo download 3.3 firmware version for Wizard remote?
Perfect! I,ve just downloaded and modified its extension. Updating tomorrow. thanks, again, a lot !You can download the Updater and the manuals from the downloads repository on YuneecSkins.com. Firmware v3.0_2016 is there, but I am attaching v3.3 here. After downloading v3.3 remove the .txt from the end of the filename, it was added so it could be uploaded here. If you are running a version of Windows earlier than Windows 10 you may need the STM32 Virtual COM port driver mentioned in the updater instructions, here is an updated link to the download https://www.st.com/en/development-tools/stsw-stm32102.html
