Wizard info
Italy
I just started using the Wizard, and are still the basic functions.
Then I ask you some question, hoping you have a better idea than me:
1) The keys 9 and 10 (tilt up and down in 1.1. Manual), when pressed alone (ie not with other keys), what do they do?
2) 'POINT TO FLY' function, always works the same altitude ?
That is, every command I give in this mode, only changes the H position, but not its altitude ?
3) by default, altitude follow function, in on or off?
Thanks for any response.
Reactions: Steak frites
No one has a tip?
At least for point 2 ?
Or tell me if my English is so terrible that you can not understand.
I hope I found the right one. The guy who did a very good one is a member here and I think this was it. Search is your friend.
I would have never taken mine out of the bag it came in if I hadn't watched that video first.
wiebeedigital
