Yaw Motor wiring
Desperately seeking help..
Hello All... I recently went "Tree Trimming" with my Typhoon H. A couple of parts got broken, but nothing irreparable.
HOWEVER... the wires from the camera gimbal were separated from inside the Yaw motor housing. Can anyone direct me to where I can find a schematic to reconnect these wires? They did not disconnect from the hot shoe (slide mount)..
They were disconnected from inside. PLEASE and Thank you!
UPDATE: It's actually the wires from the HOTSHOE to the little black gizmo in the center of the Yaw motor...
This is the slide mount plate inside the upper gimbal for the CGO3+. Note the black wire is difficult to see in the photo. These wires are actually going to a slip ring which is not really a motor. If the wires are broken too closely to the slip ring they cannot be repaired and the slip ring must be replaced.
Reactions: WTFDproject
nextsi
