Yneec CGO3 + in own constructions.
If you can please communicate in English, this will help in getting comments and responses to your question.
He did some investigations, how control og the gimbal works. He tried some PWM generators to figure out how it works and what happens.
To initialize the camera a start signal is needed (this was already discussed for CGO2/3 cams with different solution in order to use the cams with other copter than Yuneec).
From video description:
Power supply: 3S or 4S battery (at least we need 5V which is made by a step-down voltage converter TPS5450, thus it will also work with 2S).
PWM signal characteristics:
- frequency: 50-200Hz
- amplitude: 3-5V (3,3V)
- Initialization signal: 630 - 660 μs
- Signal to block tilt: 900 - 1040 μs (see at 04:15)
- Signal to control tilt: 1100 - 1850 μs
Nice to see that also another receiver and RC controller is working with the CGO3+ (see from 11:20 on).
daps20
