Yuneec cgo3 plus camera shakes, spins and no control
Did you unplug anything from the gimbal board? Any broken wires? Any crushed wires during re-assembly?
No. I just found the magnets broken. It was the first thing I looked for. I am not sure if the original owner did anything though.
I wanted to update this a little.
I found that when replacing these magnets, you have to get the placement of the magnet's poles correctly aligned. Also, the spacing between the magnet and the encoder must be even. I marked the tilt axis magnet (on the side of the camera) and turned it slightly. I would put the encoder back on and test it. If the shaking was still present I would repeat the process until I got it to a decent stabilized position. I learned that if this magnet is off by 1-2mm it causes the camera to spin and shake out of control. I have it almost steady but the yaw is off a bit.
Ludwig
