Yuneec Typhoon H queries
First off I'm new to forum but hoping to find some answers. I passed my CAA flight assessment UK the other day. But in doing so I had to demonstrate Return to Home mode. In doing so my Typhoon H climbed to 290ft before returning to home! WTF! The manual said 10 metres. That's about 32 ft. Also I've noticed that upon landing it takes a few seconds of stick down before the engines will idle. This has resulted in a couple of landings where the Typhoon became unstable on the deck. Why don't the engines go to idle quicker? Help....
Go into your ST 16 and you can adjust the return to home height. When I land I always put the left cyclic all the way to the bottom for 2 to 4 seconds and then I press the red button and everything turns off.
Thanks for your response. I wasn't aware you could change the RTH height. The manual states 10 metres. Where the St16 menu can you change this?
well done im about to take my flight test once ive got the ops manual done
Smyers
