CG02+ Error
I crashed my Q500+ many years ago. The camera worked perfectly fine for a while after the crash. Then it started beeping (2 long, 3 short) and shaking to the beeps. The camera is also in the same crooked position all the time now. Any ideas? Camera is CG02+. Thanks!
The IMU has probably drifted out of calibration. There is a work-around that may help.
1.) Tilt the Q500 back to rest on the rear motors and rear tips of the landing gear.
2.) Power on the Q500.
3.) When the camera initializes, place the Q500 into it's normal standing position.
If the camera initializes, it will only stay initialized until it is powered down. The sequence has to be repeated at each start-up.
barkercollege
