CGO 3 4K PLUS
Yes. Just select CGO3 Pro as the camera. Then bind to that camera using the password 1234567890.
[QUOTE="can I bind a (CGO 3 4k plus)[/QUOTE]
The extra word "plus" in your post, and it's placement, worries me a little. There is room for misinterpretation there. There is a CGo3 4k camera, and there is a CG03+ 4k camera. Both are 4K cameras, share a lot of common components, and even look a lot alike, but they are more different than you might think. Also, In another post, you were in a thread talking about a Q500+ drone, which I THINK came with the original ST-10 controller, not the ST-10+ (I'm not sure about that.). In that other thread, you included a stock picture of a Typhoon H. This is a LOT of possible combinations, and the answers are different for many of the combinations.
Are you asking if you can mount a standard CGo3 4K camera to a Q500+ drone and fly it with the original ST-10 controller? That would be a "YES". You just have to use the camera's pigtail to power it, and upgrade the ST-10 firmware to the latest release to provide an option to select the CGo3 camera.
Are you asking if you can mount a standard CGo3 4K camera to a Q500+ drone and fly it with the newer ST-10+ controller? That would also be a "YES", and it's even easier. You just have to use the camera's pigtail to power it.
Are you asking if you can mount a CGo3+ 4K camera to ANY Q500 series drone (or Chroma) and fly it with either of the ST-10 controllers? That would be pretty much "No", from a functional standpoint. IF this is what you meant, be aware that there are some significant conflicts between the drone itself and the camera.
Or are you asking something else? If so, please clarify which camera, which drone, and which controller you want to use together. That would make it much easier to give you an answer specific to your need.
IF you are asking about flying either camera on a Typhoon H with either of the ST-10 controllers, someone else will have to answer. I don't have an "H".
revile
