- Joined
- Dec 13, 2016
- Messages
- 32
- Reaction score
- 2
- Age
- 62
Not sure I understand your question. The wires shown in the photo are connected to the JR plugs that are plugged into the FCØ. Number 1 goes to M1 on the FCØ, etc etc. These wires then let the FCØ control the electronic speed control ( ESC) which then control the motors. I am not sure which arm is controlled by M1. If you can connect to the GUI, each motor can be verified by actuating them individually from the GUI diagram.Thanks which arm is the number 1 motor on pic please
Can you tell what arm has the number 1 motor on it and how count the arms like 1 to 6Not sure I understand your question. The wires shown in the photo are connected to the JR plugs that are plugged into the FCØ. Number 1 goes to M1 on the FCØ, etc etc. These wires then let the FCØ control the electronic speed control ( ESC) which then control the motors. I am not sure which arm is controlled by M1. If you can connect to the GUI, each motor can be verified by actuating them individually from the GUI diagram.
Thanks I just see your board pictureCan you tell what arm has the number 1 motor on it and how count the arms like 1 to 6
