Flir veu on plus?
So as we all know yuneec has still not given the plus more camera's to put under it. I would love to use the E10 but doubt yuneec will release it for the plus. So my question is: can you put a flir veu under it and if you can, does anyone know how to do it? I think it should work cause it is pixehawk based right??
You face the problem using either camera. No control over the camera functions from the controller.
Yes you would think so.. But yet you see people who get it done on a 520 like in the link above. I was just wandering if some one with a plus did it or understud how it should be done. Pure on theory i think its possible, and with the pixehawk opensource inside my logic (for what its worth) tells me it should be easyer than with lets say a 520?
I haven't seen a follow up from Uwe. It is interesting that they found a way to split the camera control signal to control the tilt on both cameras.
snoopy68
