Goes horizontal after take off
After take off, goes sideways and difficult to controll. Appears to be always the same direction. GPS is good on controller and drone. Controller appears to not have stick problems. Controll board replaced. Compass calibrated.
Help? TIA.
Are you flying in Smart mode or Angle mode?
Are the sticks reacting properly in Hardware Monitor?
Enter the Final Output display by tapping on the Volts readout on the ST16.
With the sticks centered CH2 should be at 0% moving the right stick left and right should cause the value to change between 100% full left to -100% full right (with the Rate Slider at full rabbit position). Move other controls and ensure CH2 does not change value.
Thanks for the reply. This in angle mode. Tried smart mode with same result.
I'll try to reproduce your results with Typhoon GUI and ST16 hardware monitor.
Reactions: DoomMeister
The final output display is accessed by double tapping the Volts on the ST16. The aircraft does not need to be on to test the output of the ST16.
As @h-elsner suggests, your flight logs from these errant flights could give us a clue into the cause for this behavior.
Reactions: 7cyclops
CH2 is at -015% and is slow to zero, then goes -015%. Other controlls snap to zero and stay at zero.
This help from y'all helped me find this:
I'm gonna get some contact cleaner and try again. Stay tuned . . .
Sacha
