H520E Repair Service
Where can I get my H520E repaired? Vertigo Drones appears unresponsive. Yuneec Skins is going through an unfortunate tragedy. There appears to be little to no support for Yuneec Service Centers.
Important diagnostic questions for OFDM drone/camera repair:
Did any/all camera mount dampers come out?
Did the camera mount base detach from the drone?
Other than that, most of the damage appears fairly routine and will only require parts that are the same for all the H520 sized models. Some models are not orange, but the parts are otherwise the same parts.
The obvious damage to the camera itself is repairable. If the camera ribbons are broken, it may be a bigger issue.
The broken antenna mount may be an issue because I know of no currently available replacements for the special lamp shade it uses . At least none I know of.
At least one other drone was fixed by coming up with a home made remedy that worked for that case. Not sure what will work for yours.
mbecks
