Help - GUI Reports Bad IMU
Because this was an interesting case I never saw before I would like to have this defect controller board. If you are willing to send me this I will send you back a working one.
Stupid idea but you can try. Disconnect the IMU and try to do an ACC calibration. Probably you'll have an FCU with wiped callibration data.
I do what he says Vaklin ?
Ne. Ne pokušavajte @Valkinov prijedlog.
@Vaklin je predložio mogući način na koji bi se problem mogao stvoriti, a ne način da ga se riješi. @Vaklin i @h-elsner su dva pametna momka. Pokušavaju shvatiti koliko se loše stvari događaju kako bi pomogli pronaći napredna rješenja za probleme.
No.
@Vaklin's suggestion is a possible way to create the problem, not a way to fix it. @Vaklin and @h-elsner are two of the smart guys. They try to understand how bad things happen to help find solutions.
Mihal05
