- Joined
- Jul 14, 2018
- Messages
- 184
- Reaction score
- 67
- Age
- 73
A quick search of the subject here in the H Plus forum didn't turn anything up, so I'm going to take that to mean it's not common.
Today while flying I flipped the RTL switch and all went well. When the drone paused to lower its gear, one support came down while the other didn't!
I have not ever attempted to grasp it with the rotors still going, (while hitting the red button to shut down.) I did flip the gear lowering switch to manually
see if it would resolve it but to no avail. Now as I recall, in my panic, I don't think I took it off of the RTL mode. I should have done that and tried to manually
get the gear to drop using the gear switch. But I digress …
I went ahead and descended to the ground as gently as possible and landed it. It tipped to the side but I think I got
the off button triggered in time because there appeared to be no damage to the two rotors that brushed the ground when tipping to the side. My biggest
fear was for the exposed camera (it was resting on gravel in a parking lot) but I believe the rubber piece behind the camera and slightly lower protected
the camera from damage. Whew.
Then it was a matter of how to get the gear back up. Unfortunately, the only way to activate that mechanism is when the drone is on and the rotors turning.
I managed to hold the drone off the ground in one hand while holding onto the controller and pushing the red button to start the drone. Once it was hovering (all appeared normal but for that one gear) I activated the gear switch and this time the gear that was stuck up came down. Several more times I raised and lowered the gear to make sure
it wasn't going to do it again and it seemed perfectly fine.
I'm wondering if anyone else has had that problem? A glitch? Helpful advice on grabbing the drone and powering down while it's hovering is welcome.
