typhoon h not tilting and pan
hi there. i am new on typhoon h and i use 3 times it. today i try to use my typhoon h but tilt control doesn't tilt the gimbal and when i turn the pan control button gimbal doesn't pan. so i can fly the aircraft and record videos or take photos. there is no problem. but when i try to til or pan there is nothing. gimbal doesn't tilt. You can see my controller's screenshots and aircraft video below. how can i fix this issue?
Your Typhoon H is not correct bound. rebind it.
Also, your firmware is from august 2016 :rolleyes:
hi everyone again. i updated my controller and my aircraft succesfully and rebind it. bur still my tilt and pan button not working. when i move to tilt or pan button controller beeps once. i can use other specifications on the controller ( fly, record, take photo etc.) but i can not til or pan the cam. i really don't know how can i solve this issue. :(
again me :) i detach the gimbal deom the copter and then attach it again then my problem is solved. i really don't understand what happened but it's working right now. thanks everybody to help me.
Reactions: wedbster
mindfiresolutions
