Yuneec Mantis Pilot app
My pleasure folks! I wish I knew what was going on with Yuneec and Google. The Android version of the Breeze Cam app was dropped from the Play Store earlier this year.
Quite honestly if you have a compatible iOS device it would be better to use it anyway as that version is more feature rich than the Android version.
My son with an iphone can not connect, it says sometimes control by another device, mostly will not be able to scan the sticker with fail connection any tips
Ok, I’m assuming you found the Yuneec Pilot app on the iOS App Store.
Have you used any other device to connect to the Mantis Q. If so you need to disconnect it from the Mantis WiFi. It will only allow one at a time.
This video shows the binding procedure.
For more detailed binding instructions see page 10 in the attached manual.
Did you ever find the app because I can't find it either
Welcome to YuneecPilots!
For iOS devices you can download it at the App Store ‎Yuneec Pilot
For Android devices you can download it here Android App
Since it is not on the Play Store you have to download it, enable installation of third party apps in Android Settings, and then install the Yuneec Pilot app.
For either version of the app you can find instructional videos when you select the icon on the top right that looks like a bust.
Kkit
