Yuneec Typhoon Q500 4K Battery
Türkiye
Website
53r.com.tr
Hello . The batteries of my Yuneec Typhoon Q500 4K Drone are very weak and the time to stay in the air is very short. If I empty these batteries and fill them with a lithium battery, can I fly the drone for a longer time? How many 3.7 volt batteries should I place in it? From the attached batteries.
It uses a 3S (3 cells in series) LiPo pack. 11.1V nominal voltage. So when fully charged it will be at 12.6V (3x 4.2V/cell).
That would be possible but you need high Ampere cells. That are vera rare and expensive. Cells should have discarche current more than 30A peak. You can use 10A cells parallel (3s2p). Also you need low voltage protection and over temperatur protection. Only use an intelligent charger for LiIon batteries.
pdqflyer
