16.6volts out of 12 volt system
I have four conditioned batteries and they register 16.6 on the ST16 from the beginning to now with many flights. Never have obtained the magical 16.8.
I am unsure it matters. That is so close, could be just the way it is reporting it. If it is fully charged then you should be good.
Reactions: DroneClone
For some reason I'm only showing 16.6 on my ST16. I have figured out that stated voltages on the outside of the batteries is the storage amounts when you let them set up.
my full charge also shown 16.6 from the ST16, i use multi-meter to measure it about 16.7xxx
Sierrarhodesss
