Would there be any noticeable gains on putting on longer antennas replacing the ones on the two antenna typhoon series ? Just curious, don't have any problems, just a thought ?
I noticed theres an after market antenna attachment for the earlier 480 where the antenna was either inside the lower cover, or sticking out ( not familiar with it) where they change to add on antennas on the lower cover by the legs ? This led me to ask that if I changed the short antenna wires on the H, and H+ to the longer antennas if there would be an connection improvement, or not ?The length of an antenna depends on wave length/frequency to have optimal impedance matching.
What do you mean with longer antennas? Longer wire or special construction?
It's not easy to create antennas with optimal efficiency.
Antenna (radio) - Wikipedia
en.wikipedia.org
The idea of this change was to move the antenna outside of the cover. This minimises the shielding and also moves the antenna further away from the electronics which might cause interferences.This led me to ask that if I changed the short antenna wires on the H, and H+ to the longer antennas if there would be an connection improvement, or not ?
