3400 mAh vs 7500 mAh
If the weight is heavier than the OEM battery, the aircraft will have more load to carry and could overload the motors/ESC's. In that case the additional flight time you might expect will not happen. If you choose another battery compare the weight first.
Gotcha. Thanks.
guardianangelstowing
