3D MAPPING POSSIBLE?
Well, yes. The learning curve is nearly vertical. However, I don't know if the CGO3 adds a geotag to the pics. The CGO3+ does. You will need to verify that. I haven't done any 3D but I've seen others post samples from the H.
Reactions: Marcius1979
There was a discussion here with a workflow, how to do mapping with Q500.
CGO3 pics do not have coordinates in EXIF data.
Here is a project to add missing EXIF data from telemetry data:
Did you tried do this update?
I do not mapping. The links are only what I found or remember regarding mapping with legacy Yuneec multirotor.
No special firmware update needed at all. All the procedures points to postprocessing, tagging the pictures with geodata and so on.
taxinnovex
