Ok, I am having to revisit this thread, on account of a continuing video problem that as yet I am unable to resolve or find any information about !
I made this video to demonstrate a barometer problem / descent issue, but it also turned out to be highly demonstrative of a rather more worrying problem I am getting every time with 4K video from the CGO3+. As you can see from the above, I have solved the movement juddering by transcoding, but what remains are these annoying 'blurry dim flashes' every 1 second throughout this video, and on every 4K video I have ever taken with the CGO3+ ! Doesn't happen at all with 1080 source footage as far as I can see.
So, are you seeing what I am seeing ? It is worst at the following times in the video below:
1:11 - here the dimming flashes are almost in time with the music !
1:34
2:22
2:58 - very much ruining my nice panning shot there !
...but it's actually going on most of the time, just very subtly, but definitely to the extent where it is ruining my videos ! Note I am not talking about the youtube compression that regularly blurrs out my near-ground level shots, but the regular pulsing dimming that goes on in addition to that !
I can put up with all sorts of flight problems with the Typhoon H if I can only get decent video out of it in the end, even if that takes some effort, but knowing as I do that this particular problem is in the source footage too (the grade makes it worse / more noticeable, but it is there in the files directly out of the camera) and as such might be unsolvable, so I am beginning to think that unless my CGO3+ is broken, I may have to return, or sell the H and try and find some other platform where I can reliably get decent 4K footage. As much as it would gall me to go back to horrible DJI, the Mavic 2 Pro does produce incredible footage, and seems like it might just... work.
So is this every CGO3+, or just mine that does this do you think ?
One last thought - Every time I have done a 4K video, I have had one of those cheapy Neewer ND filters on. I don't suppose that could have anything to do with it could it ?
Thanks guys
J
1:34
2:22
Thanks guys
J
