Hi folks!
1) What would make the H lose GPS? Does the number of GPS satellites on the H increase the redundancy in case a satellite is lost or does it just increase the position accuracy of the H? Why would you lose total GPS and have to enter into manual flight if you begin with 15-18 satellites? Surely you do not lose all satellites at once....or do you? Or is losing GPS a flaw in these things? Not that I have lost GPS while flying (knock on wood) but have lost GPS while on the ground and it made me think of these questions.
2) Why does the number of satellites on the H not always match the number of satellites on the ST-16 since they are in the same area and should "see" the same number of satellites?
Thanks!
Thanks!
