Altitude problem
Hi,
I cant fly it more than 5 or 6 meters.
I did every setting right. But it still dont go higher.
I do not use gps. Is there an altitude limitation when gps is off?
I believe it will be limited to 10 feet if you are using it without GPS. If the GPS is off I think the indoor sensor is on by default and therefore you are limited. I will check with my unit later.
TroyBoy
