Anti Drop Pins
Winter Springs, FL USA
Got the Dampeners installed no problem, but having trouble getting the washers to clip on the anti drop pins.
Any Hints?
didn't find anything on youtube
TIA
Nick
You need nimble fingers of a monkey and patience of Job. Try tiny needle-nose pliers.
You don't need washers, or the retention pins, at all. Bear in mind the retention pins are not there to prevent the vibration isolators from separating from the mount, but there as a protective device to keep the entire camera from separating from the mount and/or aircraft during a crash. There are numerous ways to accomplish the same task, and the pictures below provide one of them. You can do just two corners or all four. All four is the best way. Release cover_1.jpg Release cover_2.jpg Access to isolators.jpg string through.jpg Loop secure.jpg Job complete.jpg
Reactions: Guess Who
Had to fit a replacement gimbal mount kit last night. The rubber dampers went on easily with the help of a length of dental floss would round one end and pulled through the housing. Fought for a while with the pins until I used some needle nose pliers to grab just below the bulbous area under the split. Holding the pin from there the washers were easily pushed on with fingers.
netnetweb
