After analizing telemetry data and experimenting A Lot with the channel mixer I was able to achieve a method to enable/disable using the Aux button.. Well, sort of; it is actually a combination of the Aux button + the Rate (turtle/hare) slider.
It kind of works; it is at most an iffy work-around.
I havent tested it while flying, as I mentioned its just a workaround and its not reliable (sometimes you have to try a couple of times to enable/disable) until I find a solid solution I consider it just an table-top experiment.
Anyway, it is nice to be able to see this work without having to use the screen at all.
Greetings!
Greetings!
