- Joined
- Mar 4, 2019
- Messages
- 400
- Reaction score
- 211
- Age
- 55
Guys I am going to attempt to build a Typhoon battery from scratch. I found these Lipo cells online for 6 bucks each. I will be using 4 3.7v cells with 5900mAh that are rated at 20 amps. Here are the specs:
- Brand: Vapcell
- Model: INR26650 5900mAh
- Size: 26650
- Positive: Flat
- Stackable? No
- Type: Rechargeable Lithium Ion Battery
- Protected: No
- Nominal Voltage: 3.6V
- Nominal Capacity: 5900mAh
- Continuous Discharge Rate (CDR): 20A
- Approximate Dimensions: 26mm x 65mm
