  1. Agent K
    Green Bay, WI
    I'm trying to find info on the following -
    1. What is the appropriate storage voltage? For how long?
    2. Should fully charged batteries be discharged? If so how? (I do not like the idea of running them down, why wear my motors down)
    3. Is there a balance charger out there people are using? Have you had success with it?
    4. Are there adaptors for an aftermarket charger?
    I found some info but this would be a good sticky thread since flying may slow down with the colder weather approaching.
  2. DroneClone
    Texas
    1. 14.8V Storage As long as you like!
    2. Yes, but only if not being used more than 7-10 days( Buy an Rapid Charger, that has a discharge function, like a HiTec 2)
    3.HiTec 2 or 4
    4.Yes, Carolina Dronz and others have them
    BillyTexas likes this.
  3. BillyTexas
    There you go DroneClone has the answer. Very simple to figure out. Glad you are enjoying your H.
    Bill W.
  4. Brian Mackey
    Eagle Idaho
    wait, what? 1. 14.8V Storage As long as you like! Really??
  5. Rayray
    Rayray Moderator
    Staff Member
    Pine Forests of Deep East Texas
    I believe that is the recommended storage, 14.8 volts, typically written on the 4S batteries.
  6. Brian Mackey
    Eagle Idaho
    I'm all confused that's not whats on MY H battery
    My charger puts the H battery's in storage mode at 3.8 v each cell
    abinder likes this.
  7. Rayray
    Rayray Moderator
    Staff Member
    That's OK. 3.8 times 4 cells is 15.2 volts, if my pea-brain is right. Probably anything from 14.6 to 15.2 will work.
    abinder likes this.
  8. Brian Mackey
    Eagle Idaho
    Okay I was getting dysfunctional there for a minute LOL
  9. Agent K
    Green Bay, WI
    What charger are you using?
  10. Brian Mackey
    Eagle Idaho
    Cesar likes this.
  11. abinder
    Most of the popular chargers (HiTec included) have the default storage charge for 4s batteries at 15.2v.
    Brian Mackey likes this.
  12. Cesar
    What's the AMP that I should configure on my Hitec for the TH? 5.0 or 6.0?
  13. Brian Mackey
    Eagle Idaho
    I use 5
    abinder and Cesar like this.
  14. BillyTexas
    For the H batteries its 5.4 amps. Thats charging at 1C.
    Bill W.
    Cesar likes this.
  15. Cesar
  16. abinder
    Which HiTec model do you have?
    Most of the HiTec chargers can only supply 50w per channel.
    At 50w charging, you won't be able to charge a 4s battery at 5A.
  17. JCFlippen
    Cardiff-Wales UK
    When using mains power my Overlander (Hitec) x2 charger supplies 3.2 amps per battery.
    abinder likes this.
  18. Cesar
    Is a Hitec multi charger X4 and for Lipo it can go as high as 6A
    [​IMG]
  19. Agent K
    Green Bay, WI
    So what are the appropriate chargers to purchase that can do the job?
  20. ArnhemAnt
    Northern Territory, Australia
    I use my Revolectrix PL8 along with the MPA boards. Have done for years. I can balance charge up to 9 batteries (at 1C) at a time.
