Best way to take screenshots from ST16
Poland
Like in title, could anyone tell me what is the best way to take screenshots from ST16 in good resolution?
St16 can only do 720 resolutions
Best method is to use your computer/laptop using the micro card.
Press and hold the middle tablet button for three seconds and the St will record everything on screen into a Photo stored in the gallery, as AH explains - it will only be a 720 P size image however
Reactions: DCH
In Cameras I have got SanDisk MicroSD Gold ones with 64 Gb of capacity, in ST 16 I have a normal micro SD card from SanDisk also but Ultra model with 16 Gb of capacity.
On the other hand, if you are talking about recording the screen as a video, to capture all of the screen info, you will need to get an HD recorder and use the HDMI output from the ST to record video capture of the screen.
Reactions: ParagonDrone
Hey @Ty Pilot , does that recorder “pass through” the HDMI signal?
As in: ST16 HDMI —> Recorder —> FPV Goggles or TV Monitor.
So, while recording, it will also pass the signal to another device?
ardigitalmedia
