With all the horror stories about LiPo batteries exploding I am considering a better charger than the one included with the Q500, any thoughts?
I have the same one, but not touch screen. Mine is the HTRC C240. I bought it off of Amazon for 60 something dollars. Does absolutely everything I need, as you mentioned. It also discharges batteries. It takes all freaking day, but it does it.I'm very happy with this HTRC Touch Screen Dual Channel charger. It puts out the same as the Venom on AC but in the car it puts out 10amps per channel. What makes it really nice is the touch screen. Makes it fast and easy to set up your charge and save and access memories without all the button pushing, and you can monitor the battery temp, charge current and voltage at the same time along with a graphic display of the progress history. You can also see each cell's status on the display at a glance. That is a very handy feature for spotting a problem cell. @Fred Garvin also has one and loves it. The price is competitive maybe even cheaper, it's smaller and very robust.
View attachment 16090View attachment 16088View attachment 16089
HTRC HT-0099 240W 10A RC Lipo Balance Battery Charger Discharger for sale online | eBay
Find many great new & used options and get the best deals for HTRC HT-0099 240W 10A RC Lipo Balance Battery Charger Discharger at the best online prices at eBay! Free shipping for many products!www.ebay.com
Hi DCH, does this come with the right cables for the Typhoon H bartery?I'm very happy with this HTRC Touch Screen Dual Channel charger. It puts out the same as the Venom on AC but in the car it puts out 10amps per channel. What makes it really nice is the touch screen. Makes it fast and easy to set up your charge and save and access memories without all the button pushing, and you can monitor the battery temp, charge current and voltage at the same time along with a graphic display of the progress history. You can also see each cell's status on the display at a glance. That is a very handy feature for spotting a problem cell. @Fred Garvin also has one and loves it. The price is competitive maybe even cheaper, it's smaller and very robust.
Hi DCH, does this come with the right cables for the Typhoon H battery?I'm very happy with this HTRC Touch Screen Dual Channel charger. It puts out the same as the Venom on AC but in the car it puts out 10amps per channel. What makes it really nice is the touch screen. Makes it fast and easy to set up your charge and save and access memories without all the button pushing, and you can monitor the battery temp, charge current and voltage at the same time along with a graphic display of the progress history. You can also see each cell's status on the display at a glance. That is a very handy feature for spotting a problem cell. @Fred Garvin also has one and loves it. The price is competitive maybe even cheaper, it's smaller and very robust.
HTRC users.
In the Extra Function menu there’s a Balance mode, has any of you tried it or know wither this is a cycle function that auto discharge and then charge?
I’ve only used the Balance Charge and Storage functions. Both automatically balance the cells then bring them, evenly, to the levels particular to the mode selected. Using Storage, it will either charge or discharge to get to the level set. It will auto-detect the battery and set accordingly, but you can tweak any of the parameters to your liking.
I see....when you select Monitor you get 2 functions: IR and Balance. I’ve used IR but not Balance.
Try it and see what happens. My guess is that it will balance all the cells, charging or discharging each cell to an average value achievable by all cells depending on current detected level.
Do you mean the End Voltage?
Typhoon H+:
Full Charge per cell: 4.35
Full Charge: 17.4
Storage Voltage per cell: 3.9
Storage Voltage: 15.6
Type = LiHV
Cells = 4S
Typhoon H:
Full Charge per cell: 4.2
Full Charge: 16.8
Storage Voltage per cell: 3.8
Storage Voltage: 15.2
Type = LiPo
Cells = 4S
I charge both at 5.4.....1C for a 5400 mAh.....safe bet since there’s some question on the actual capacity of these batteries....charges in ~ 1 hour and that’s fine.
