Binding Verification - ST10+ / Q500
WTFDproject
Moderator
Staff member
Premium Pilot
North Carolina Piedmont, USA
There are some posts already on the board that describe the routine binding of the ST10 to the Q500 series. Those are much easier to perform, and are more appropriate if you are not having problems. The purpose of this "Binding Verification" is to address abnormal conditions that are preventing a successful bind. The intent is somewhat to ensure proper sequence is being followed, but mostly it is to identify the exact point where the binding process is failing. That information can assist in determining the best course to remedy the problem.
The full document is provided as an English Language PDF. There is also an English language "text" version that can be more easily translated to other languages. An attempt has been made to translate the text version into some of the languages frequently used on the Forum.
  • ST10+ Binding VerificationR7 - English.pdf
  • ST10+ Binding VerificationR7 - English.txt
  • ST10+ bindningsverifieringR7 - Svenska.txt
  • ST10+ BindungsüberprüfungR7 - Deutsch.txt
  • Verifica vincolante ST10+ R7 - Italiano.txt
  • Verificación de Encuadernación ST10+ R7 - Español.txt
  • Vérification de la reliure ST10+ R7- Français.txt
dwight.a.atkinson
