Breeze Flight Logs
Green Bay, WI
Has anyone tried to decipher the Breeze flight logs? I was able to easily download them to my Mac and then import them by changing the file type to .CSV. However, when I looked at the data, it didn't make much sense to me. I'm mainly interested in only 3 parameters: flight time, height, and distance. While the flight time seems accurate, the data for height and distance does not look correct as they never change.
Reactions: Kybipix
A simple question: Ho did you download the "flight log" from the breeze?
Keep in mind that I use an iPhone 6 to control my Breeze, and my desktop computer is an iMac.
To download the log files I connect my phone to my desktop. On my desktop I open up iTunes. In iTunes I access my phone. Under Settings, I click on Apps. Scroll all the way to the bottom and you will see all apps that contain data that can be accessed. Click on Breeze Cam and you will see a number of files and folders. The two folders I downloaded are called FlightLog and Log. I simply dragged those folders to my desktop to download them.
I believe you can do the same with an iPhone and a Windows desktop using iTunes. As for an Android device, I cannot say. However, I believe there are utilities that allow you to access data files on your Android phone which you can then download.
Thank you so much! Will try it soon on my PC!
Download Flight Log's from Android to WIN10-PC: Open "Internal Memory" from your "Hi Suite App" (Huawei P9) and find the folder "BreezeCamLog". Copy it to your Windows System.
With the location informations it's possible to find all flight positions.
But here are some questions: What means ...
  • flightMode ? ---- I found in my list only 0 and 3
  • loseGPSAct ---- I found in my list only ciffer 1
  • motorStatus ? --- I found in my list only 15
Thanks!
I do not know a lot of the Breeze FlightLog data because Yuneec did not offer a description. What I already know is decoded in the following program:
Download Win: http://h-elsner.mooo.com/downloads/q500log2kml_en.zip
Description: http://h-elsner.mooo.com/mydat/Q500log2kml_en.pdf
LINUX: http://h-elsner.mooo.com/downloads/q500log2kml_en.tar.gz
Motor status has 1 bit for each motor. 15 = 1111 means all motors ok. If one is OOS the related bit goes to zero and a numver smaller than 15 will be shown. In the program above double click in a cell and you will get more info in the status bar (i.e. what motor is down).
I 'think' this is it...
seems i can't attach .log files
sorry this is long but this is the text file
YC
StartTime:2021-03-20 05:01:07
Platform:Android28
FC:10000,ESC:10003,Camera:10000,App:83
DroneSN:YU16390FBEB09A01
HardwareInitStatus:0
UTC,TimeStamp,flightMode,distance,height,loseGPSAct,goHomeHeight,maxHeight,maxDistance,maxSpeed,alt,IMU_Sta,lat,lon,AutoTakeOFF,roll,pitch,yaw,motorStatus,errorFlags,nsat,voltage
2021-03-20 05:01:08,48,0,40,20,1,300,800,959,500,-20,-81,525186527,-18436982,0,-5531,-128,61,15,0,-113,198
2021-03-20 05:01:09,49,0,40,20,1,300,800,959,500,-26,-81,525186411,-18437077,0,-6679,-109,2306,15,0,-113,198
2021-03-20 05:01:10,50,3,40,20,1,300,800,959,500,-29,-17,525186303,-18437161,0,-11242,-2638,5698,15,0,-113,196
2021-03-20 05:01:11,51,3,40,20,1,300,800,959,500,-18,-1,525186209,-18437237,0,-10374,-2944,4350,15,0,-114,197
2021-03-20 05:01:12,52,3,40,20,1,300,800,959,500,-4,-17,525186145,-18437233,0,-5333,-1191,-326,15,0,-113,197
2021-03-20 05:01:13,53,3,40,20,1,300,800,959,500,2,-17,525186024,-18437248,0,-997,1109,4797,15,0,-113,198
2021-03-20 05:01:14,55,3,40,20,1,300,800,959,500,-3,-17,525185872,-18437225,0,-1200,1050,5315,15,0,-113,197
2021-03-20 05:01:15,56,0,40,20,1,300,800,959,500,-6,-81,525185716,-18437251,0,-709,632,6225,15,0,-116,198
2021-03-20 05:01:16,57,0,40,20,1,300,800,959,500,-8,-81,525185563,-18437269,0,-312,114,5765,15,0,-113,197
2021-03-20 05:01:17,58,0,40,20,1,300,800,959,500,-6,-81,525185394,-18437273,0,876,191,5109,15,0,-113,197
2021-03-20 05:01:18,59,0,40,20,1,300,800,959,500,-6,-81,525185267,-18437325,0,-413,397,4631,15,0,-113,198
2021-03-20 05:01:19,60,0,40,20,1,300,800,959,500,-4,-81,525185143,-18437390,0,-552,375,4550,15,0,-112,198
2021-03-20 05:01:20,61,0,40,20,1,300,800,959,500,-9,-81,525185023,-18437436,0,-749,673,4281,15,0,-113,198
2021-03-20 05:01:22,62,0,40,20,1,300,800,959,500,-10,-81,525184866,-18437496,0,-1595,931,3972,15,0,-113,198
2021-03-20 05:01:23,63,0,40,20,1,300,800,959,500,-9,-81,525184700,-18437530,0,198,-1300,5889,15,0,-114,196
2021-03-20 05:01:24,64,0,40,20,1,300,800,959,500,-9,-81,525184529,-18437573,0,-569,-1325,5427,15,0,-114,197
2021-03-20 05:01:25,65,0,40,20,1,300,800,959,500,-11,-81,525184378,-18437612,0,-24,-1116,5289,15,0,-114,198
2021-03-20 05:01:26,66,0,40,20,1,300,800,959,500,-12,-81,525184231,-18437622,0,255,-1290,5100,15,0,-112,198
2021-03-20 05:01:27,67,0,40,20,1,300,800,959,500,-9,-81,525184097,-18437627,0,-2496,-3037,6867,15,0,-112,197
2021-03-20 05:01:28,68,0,40,20,1,300,800,959,500,-14,-81,525183950,-18437683,0,-2191,78,1007,15,0,-112,197
2021-03-20 05:01:29,69,3,40,20,1,300,800,959,500,-12,-17,525183786,-18437748,0,-4410,91,-113,15,0,-112,199
2021-03-20 05:01:30,70,3,40,20,1,300,800,959,500,-5,-17,525183655,-18437705,0,-4971,-1321,-4650,15,0,-113,198
2021-03-20 05:01:31,71,3,40,20,1,300,800,959,500,0,-17,525183552,-18437582,0,-2856,-3894,-8360,15,0,-113,198
2021-03-20 05:01:32,72,3,40,20,1,300,800,959,500,-5,-17,525183478,-18437415,0,-4159,-3776,-8090,15,0,-113,198
2021-03-20 05:01:33,73,3,40,20,1,300,800,959,500,-10,-17,525183410,-18437260,0,-4769,-5357,-8957,15,0,-112,198
2021-03-20 05:01:34,74,3,40,20,1,300,800,959,500,-8,-17,525183353,-18437075,0,-4964,-3116,-9780,15,0,-112,197
2021-03-20 05:01:35,75,3,40,20,1,300,800,959,500,-3,-17,525183315,-18436881,0,-4936,-1458,-12510,15,0,-112,198
2021-03-20 05:01:36,76,3,40,20,1,300,800,959,500,2,-17,525183391,-18436742,0,-3201,-1607,-15586,15,0,-111,198
2021-03-20 05:01:37,77,3,40,20,1,300,800,959,500,-3,-17,525183535,-18436667,0,-2307,-441,14708,15,0,-110,198
2021-03-20 05:01:38,78,3,40,20,1,300,800,959,500,-9,-17,525183663,-18436615,0,-4311,594,11091,15,0,-110,198
2021-03-20 05:01:39,79,3,40,20,1,300,800,959,500,-6,-17,525183791,-18436563,0,-4572,750,9877,15,0,-110,198
2021-03-20 05:01:40,80,3,40,20,1,300,800,959,500,-17,-17,525183887,-18436522,0,-6366,1420,8347,15,0,-111,198
2021-03-20 05:01:41,81,0,40,20,1,300,800,959,500,-28,-81,525183900,-18436514,0,-6582,1246,10393,15,0,-113,199
2021-03-20 05:01:42,82,0,40,20,1,300,800,959,500,-27,-81,525183923,-18436519,0,-5694,497,10574,15,0,-112,197
2021-03-20 05:01:43,83,0,40,20,1,300,800,959,500,-1,-81,525183978,-18436553,0,-5495,-930,16234,15,0,-111,197
2021-03-20 05:01:44,84,0,40,20,1,300,800,959,500,-10,-81,525183987,-18436566,0,-6036,-567,-15730,15,0,-112,198
2021-03-20 05:01:45,85,0,40,20,1,300,800,959,500,-14,-81,525183939,-18436568,0,-3443,61,-16828,15,0,-112,197
2021-03-20 05:01:46,86,0,40,20,1,300,800,959,500,-24,-81,525183902,-18436567,0,-4941,-785,15488,15,0,-110,198
2021-03-20 05:01:47,87,0,40,20,1,300,800,959,500,-34,-81,525183879,-18436590,0,-5662,-1999,13279,15,0,-112,198
2021-03-20 05:01:48,89,0,40,20,1,300,800,959,500,-43,-81,525183784,-18436562,0,-8674,443,9474,15,0,-115,195
I think this text is cut. Please attach the log file as zip file. A couple of files could be added as zip archive.
Another question: To what problem belongs that log? It's not helpful to highjack this thread.
My apologies..
I thought I was replying to my own thread I started and someone asked my to upload it.. Doh!
eringongetsu
