Calibrating controller why?
Have had tons of fun with my q, no crashes, but some hard landings, which i am getting better at.
Had a particular hard landing, and i could not record to card. figured i ruined drone, came home read up on issues, and found out to try reformatting cards and success!
Today was flying and drone would not back up, oops, was over water and that was a bad thing, quickly spun drone around and went in forward to safely land.
Read where calibrating controller might fix issue, and it did!
Tested drone and all is good...
Question is why did flying cause it to need calibrationing? seems so weird..
Just to keep it simple, think of a watch that might run a bit fast or slow.Sometimes it as to be reset to the correct time.
Lots of things can cause a need to be recalibrated.
Stick deflection after break in etc.etc..
Glad you got your Q back okay.
Patynowy
