Camera/gimbal not working fuse fix
If you are like me and have blown the camera fuse on the ESC board for Typhoon H more than once, you may want to do this.
I soldered a connecter wire to either side of the fuse and will solder a standard fuse slot on the opposite end.
I will run the wiring down to the area where the Realsense camera is mounted so I can get to it without having to take the H apart.
I just wanted to share this in case anyone else wanted to try it.
Does anyone know the fuse's amp rating?
Reactions: h-elsner
Hodgepodge
