Camera points same direction no matter where UAV faces
This makes no sense to me. You say that S2 stays at 0 in the Hardware Monitor when switched between all three positions and also state that everything works in the Hardware Monitor. That is not possible.
When moving S2 (Pan Mode Switch) Up is position 0 and the camera should face forward at all times no matter what position the Pan Knob (K1) is in. At the middle position 1 the camera should be moveable with K1 and should point to the left or right according to how far K1 is moved. Position 2 is the bottom position (global) and the camera will Pan left or right according to movement of K1. The more K1 is moved off center the faster the camera pans in that direction. Once K1 is returned to center the camera stops panning and will retain its heading regardless of a change in aircraft heading.
On the main screen of the ST16 double tap the Volts icon to bring up the Final Output display. Watch Ch10, with S2 at 0 it should read -100%, at position 1 it should read -40%, and at position 2 it should read 100%. Now watch Ch8, with K1 at center it should read 0%, with K1 at full left you should read 100%, and with K1 at full right the reading should be -100%.
the camera does not move at all,only shows the image, everything
What results did you get when looking at the Final Output display (double tap on Volts icon) when moving S2 and K1?
The camera is not properly connected to the drone and the gimbal isn't initialized.
There should be a hardware malfunction in the ring connector or the drone is defective.
Камера становиться ровно по горизонтали и смотрит ли прямо вперед после включения коптера, при отключенном питаний на ST16?
Если нет, то нужно сначала решить этот вопрос.
Переведи на английском в ответе, а то мод мне замечание сделает.
Do you get any beep codes when the camera initializes?
before updating the drone, everything was fine and everything worked , when updating it showed an error on the monitor screen resultCode = 80002, after update the camera overestimated in one place, without movement and stabilization, only shows the image, what should I do?
tried to update drone, shows error again
You might try what @PatR suggests in post #9 in this thread
Post in thread 'Typhoon drone firmware update help'
The mention of the OTA method mentioned earlier in the thread is no longer viable as those servers are no longer available.
the camera does not stabilize, stands in one place, when the drone is rotated, the camera does not move, but the image shows
vansh232
