CAN I GIMBAL CAMERA CALIBRATION? (CGO3)
There is something wrong with the camera.
The binding is done well. So, camera's screen appear in ST10+.
But! camera is out of control... It even leans sideways.
How should I handle this?
I see a lot of unresolved gimbal deflection issues with the q500 4k CGO3. There is an assumption that the operation of the compass depends on your geographical position and the place where the gimbal was calibrated. I'll test this theory or wait for the answer here
There is no compass in the gimbal or camera. The IMU for the gimbal is a MPU6050 on the white board in the camera above the lens.
I do various gimbal tests with my camera. I can't find any pattern in the gimbal error. Now the suspension worked without a break for more than an hour. Last time, after a few minutes the suspension deviated to the side by 45 degrees and did not return to its place, although it was not touched. I wouldn't want to start looking for the reason for this. First, I want to make sure that the firmware of this equipment is reliable.
maahdevbook
