Carte mère h920+
hello I have ordered a motherboard for a Yuneec h920 Plus but I have not received the right card I am requesting an exchange of the motherboard. who can tell me if the motherboard I received is good for a h920 + thank you
The board you received is without a doubt not originally intended to be used with a H920+ but with a H920. You can see this by looking at the connectors as well as the fuses which have been changed from 40A to 60A somewhere during production of the H920 and changed back to 40A when the H920+ came out. However the revision number of the circuit board is exactly the same. This means that the components used have to be very similar if not identical. As a result it should be good to be used in a H920 if you change the connectors. But this is just my guess. Please wait for someone else to confirm since the software can still be different and might not work that good in combination with another flight controller. In terms of the hardware there should be no issues.
das Board was sie bekommen haben ist für den 920+, aber für die update (Board) vom alten 920 auf dem 920+ ich habe in meinem 920+ das gleiche...
translation:
the board you got is for the 920+, but for the update (board) from the old 920 on the 920+ I have in my 920+ the same...
Das Board, das Sie bekommen haben, ist für den 920+, aber für das Update (Board) vom alten 920 auf den 920+ habe ich das gleiche in meinem 920+ ...
translation:
The board you got is for the 920+, but for the update (board) from the old 920 to the 920+, I have the same in my 920+ ...
the card is new I do not understand why the motors do not start anymore even after changing the card I still have this error message on motor 5 I conclude that the fc0 box should also be changed thank you 🙏
Telefoni
