CCC editor online - Version 1.7C
Awesome news .... well done. Really looking forward to using this once I get my new H in the next day or so.
Hopefully you can turn it into an app for the ST16 ;).
Cheers :cool:
Eric,
playing around with yr editor, is there a possibility to delete a point or an entire route? maybe I missed it.
It's looking great so far.
thnx for the work.
Dirk
Great work Eric!
ATTENTION PLEASE :
I live by the sea. So my altitude iss always between 0 or 5 meters.
I never used the H on a mountain, so I don't know how the altitude is understood by the H. Is that altitude above the sea or the altitude above the ground (I mean above where I am) ?
So be carefull when you set up the altitude of each waypoint
I have to go for 5 days... so next work on next week !
Reactions: zandoli
I would assume altitude is where the H takes off.
I fly about 90 meters ASL and the altitude shows 0 from the start point.
To have sea level datum, you would need to know the local atmospheric pressure (QNH)
and load that into your altimeter.(if you had one)
Great achievement Eric!!!! Tks for this piece of work that will be a must-app in TH flyes!!!!:):):):):):):):)
you got it ! resfresh may be necessary to see changes
Smal bug, example, 5 waypoints, A,B,C,D,E. I delete E It is gone, I make a new one, then in the editor it is E again, on the map it is F. Hope you understand what I want to say. (I am not native English speaker)
Eric, while I am not sure I will use this - just wanted to say well done!
You should email Yuneec with a link!
mining_drones
