CCC mode
Hi all, I am new on here just joined this week. I took delivery of my brand new Typhoon H Pro RealSense on Thursday and have had my first flight with it today. I am most impressed with this model, so smooth in flight. I have been looking through the manual and am interested in the CCC mode but it is not clear about how you set the waypoints. Is this through a trial flight and record the points or can it be done from a map.
Reactions: obot1981
That is the recommended method and the surest way to avoid problems. I suggest maintaining a good distance from objects and the ground.
Many people are also using UAV Toolbox - Yuneec ST-16 which can be used to create CCC flights.
Make certain you know how to quickly change direction or abort the flight if something unexpected occurs.
airconditionerservice
