Cg03
My camera is recording and doing everything it should but it's not tilting down pls help
There is a cable labeled "pwm" on the camera when you take it apart. That may have come loose. Use the extra camera cable it came with to see if that fixes the tilt. If that cable does, then you might need to re solder the cable inside the camera
Axel66
