CGO2+ wiring
Hi... the Q500+ hit a tree and dropped about 8 feet into soft damp grass. Broke one prop. The CGO2 broke away. But the 2 connectors look mostly intact and were just pulled from the input jack. The pins seem to be unaffected. But I am not sure where the wires plug back into. If I run these leads into the back of the base... does one go to the right and the other to the left side? What is the best way to secure them back into the connection?
Just a few mins prior and upon startup one motor spurted and did not start up. Power off/on and it came back. Seem to fly ok. But my 'little one' was flying it and just got too close to a tree... I could not recover in time :(
I think I need to connect the Q to the PC and see if that motor has a issue...
Thanks in advance!
scan02
