CGO3+ Firmware update without useing a Typhoon
Hi together, i face a small issue. I have a crahsed and repaired CGO3+ but no more a Typhoon H.
I know that on the CGO3+ camere is the US Firmware installed, so i can´t find the cam with my smart device here in Germany.
Does anyone know if there is a way to update the firmware of the CGO3+ without the need of an Typhoon H and the ST16.
I want to use the camera for my SteadyGrip!
Maybe some of you software guys has the knowledge to do so!
Regards
Yes, that can be done if you can power the CGO3+.
You have to extract the camera update from the main TH update file you can download from the website. Here's the instructions for that...
1. Get Update File from Yuneec website, format 16GB SD card (fat32).
2. Open bin file with WinRaR, find file *.zzzzz. Double click to open new WinRar window - locate CGo3+ update file, copy to desktop etc...
3. Rename file: firmware.bin and move on to formatted card.
4. Place direct in camera, power ST-16, power H, wait. LED flashing purple while updating. Then will stop. Then power down, remove SD / reboot.
Reactions: Darksmile
ReparacionDronesMedellin
