Firmware Help
Hi
I have a Typhoon H that I installed the Realsense module on. When I look for firmware update, should I be looking for Typhoon H updates or Typhoon H Pro since I now have the Realsense unit installed. I have attached a pic of the latest firmware I have installed. Am I up to date, if not, where can I find the files to update?
Thank you,
Hi
Thank you,
You are up to date, as confirmed by the image linked below. The image is from a repository maintained by John Mitchell (@Yuneec Skins).
Special note: The image contains a reference to Gimbal Version 1.27 firmware. Version 1.27 is not an update from Version 1.25. It is different firmware that applies to a relatively rare configuration of CGo3+ cameras. You probably won't find it anywhere anyway, but if you do, don't try to load it. It will brick an ordinary camera with no recovery available other than a trip to a shop.
Hodgepodge
