CGO3 issue
Since I received my repaired camera ( new PCB ) back from Yuneec I noticed that twice out of the last 4 short flights the video would not play back. IT was there on the SD card. It showed the file size but when I ask it to play the VLC came up but no playback. However when I go to Properties and the data tab there is NO data there. I did noticed the video was choppy on the S10+. Any ideas? Thanks
First stop video capturing before power off the copter.
I suspected that maybe I had made that mistake. On 3 consecutive flights where I made sure to turn the Video off the video
came out fine. Lesson learned. Thanks!
JFI... If you forget again, restart a new recording and then close it as you should.
This will often close the last file that was open and ,make it viewable again.
Good luck,
Jafo
Good luck,
Jafo
Ok will do. Thank you
howbirds
