CGO3 on the H
I think there was mention that someone tried to use the CGO3 from their Typhoon 4k on the H....does anyone know for sure if the CGO3 is compatible with the H...would it just be plug-n-play? Does anyone have any sample images from that setup?
Based on the threads regarding the CGO3+....I'm assuming the CGO3 would produce better quality images?
Also, what about the ST10 transmitter...would that be compatible with the ST16 for the purpose of being the secondary controller for the CGO3+ or would it have to be at least the ST12 or ST16?
Non of the pieces are interchangeable between the Q500 and the H. I get better imaging from the CGO3+. The ST10 has 10 channels and the ST16 has 16 channels so the ST10 will not work with the H nor will it bind to the H or the camera. It doesn't have enough channels to control the camera functions. The ST12 will bind to the camera and is useable for Team mode.
810mscenter
