CGO3+ wont power up
Aki
I crashed my H and some wires and base are broken. So, I just got new replacement of my camera. However, it does not power up.
H turns on fine, but CGO3+ does not move an inch...
The previous broken camera was connected fine with the drone so I hope i just got a bad replacement camera.
Is there any way to check if the problem is on drone or camera? thanks.
Do you have video? If so, try re-binding the CGO3+ to the ST16 controller.
Check the contact points on the drone connection plate. I had the same problem - turns out that somehow one of the contact points became recessed. I moved it back into the correct position and all was fine again.
I have this same issue.
I assumed my CGO3+ was damaged during a crash, I purchased a new one while I try to find someplace to fix the old one.
Turns out the new camera doesn't power up either. I even replaced the contact board with a new one that was included with the new CGO3+.
It doesn't turn on, so its not possible to bind, there's just no power.
Jules,
Probably best to give Yuneec a call and have them help sort it out.
It sounds like you have done all the right things so far.
Yuneecfan49
