Charging St16 battery with SkyRc D100
I Have the Hitec X2 AC which is virtually Identical. You can charge the ST-16 battery with this charger if you have the correct connector which can be found online at places like Amazon and so forth. It is a one cell pack make sure you have the settings correct and even though it is 8700 Mah and can be charged at one C, I normally charge it at about 6 amps
and it charges plenty fast.
Should be fine... it will be a single cell, so you will not need any balance cables... just a banana plug to EC3 connector
Hey TyPilot.
I did just finished charging the ST16 battery.
I dialed in 8700MaH 3,6 V and it took 1,5 hours.
After charging a voltmeter says 4.0 volts (?)
The ST16 battery pack contains 3 18650 Lithium-Ion cells wired in parallel.
(It's kind of a micro version of a Tesla battery.)
Reactions: Typhoonpilot
No, it is considered a single cell Lithium Ion.
That may be the root reason... IMHO, it is a single cell configuration, because the manufacturer describes it as such:
ST-16 Battery
Your charger sees it as a 1S (3P).
As Eagle's eye said, it's the 1S that matters
TroyBoy
