Clips into H arm
The clips that I am trying to put inside the arm have become a real head scratcher. I got one to slide in but haven't put the screw back in yet. The other 2 no luck. I have the 3 original clips and 3 new ones. The same problem. Now what?[emoji848]
Is the issue they won't slide into place? If so, flip them over.
This might Help: Cause of Loose Motor Arms & Latch Replacement....:)
Reactions: Yuneec Skins
At least for me the new ones required some filing to fit in place. I am not sure if this is the case for you. ;)
No matter how hard I pushed on mine, they would not clip into place. I used a small flat head screwdriver and pressed the "clip" part into place and it worked like a charm. I can make a video if you need me to be clearer than that.
Axel66
